Auto Doc's
- Sep 7, 2024
- Threads
- 23
- 1,942
Why not go online and do a search, purchase a couple to keep on hand?
I always use NGK anymore for everything.Thanks! I try to stay with the brand that makes the plug for the Engine manufacturer. It has become obvious to me that Champion makes the plugs for Briggs. Not sure about Kohler. I would lean towards NGK. But I do not know. Anyone out there know for sure?
"There are 156 replacement spark plugs for Champion RA8HC. The cross references are for general reference only, please check for correct specifications and measurements for your application. When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include Amazon Associates."I use this site to cross refference plugs https://www.sparkplug-crossreference.com/
Note that heat ranges overlap.
Champions tend to be coarser than NGK's
Other than that there are a lot of charts on the web comparing the heat ranges of different plugs.
The Stens & Prime Line web pages both have charts of spark plug applications.
All of the spark plug companies have decoding tables so you can work out what all the letters & numbers mean.
You can buy OEM Kohler 14 132 11-S1 spark plugs from amazon.The Kohler spark plug the XT6 series engines take is a Kohler #14 132 11-S1. When I go to my various local auto parts stores they do not carry Kohler branded plugs.....they come up with a slew of substitutions. I don't mind a substitute if it is basically the same specs, heat range included. I know stores will x-ref to plugs with the same threads and basic physical size but other features may be different.
My on line research shows a few people are using as a substitute the following two plugs:
Champion RA8HC
NGK DCPR6E
From the part number you can see the heat ranges are different. One is an 8 while the other is a 6.
Can anyone confirm if one of these substitute spark plugs are direct replacements or do you know of another that is a direct replacement for this Kohler speced plug? Thanks.
Yes but I wouldn't have a Kohler plug in my engine even if it is an XT series engine because they use the wrong size hex head! LolYou can buy OEM Kohler 14 132 11-S1 spark plugs from amazon.
Champion RA8HC
NGK DCPR6E
Champion RA8HC
NGK DCPR6E
