Craftsman Garage
- May 2, 2021
- Threads
- 42
- 548
What I have here is a Kohler Sv735 V-twin and at low idle it has a very loud knocking sound to it, very audible from behind the engine. Full throttle and it goes away a little bit but you can still hear it, just not as clearly. (I have had one of these engines before and for those asking "why another one???" Well, I guess I wanted to flip the coin again and see "how bad can it be this time?") I have changed the oil, filter, air filter, all the maintenance related stuff. I had a Briggs single years back with rod knock, but it wasn't as bad as this. Not sure if anything can fix this or if its even problematic?
		 I will check those bolts.
