hillybilly
- Mar 28, 2024
- 56
Have you watched the two videos? Is that what yours is doing?
Before I moved the flywheel by hand all you could hear was the starter solenoid.Have you watched the two videos? Is that what yours is doing?
I've seen some videos on it but it looks like it's beyond my skill set.Even if you don't attempt to adjust your valves, it wouldn't hurt to have a working knowledge of the procedure. Also, there are prolly numerous videos on how to adjust them.
I'll bet I adjusted mine at least 8 or 9 times until I couldn't anymore. That when that little dohickey breaks and needs to be replaced.
