- Feb 19, 2020
- Threads
- 116
- 12,626
That is because MTD don't want you just buying the relay; they want you buying the whole wiring harness. I found multiple MTD built mowers that this relay is not listed for either but it is still there. This why I looked the harness image to verify that it was present or not.
It was shown on a lot of the electrical schematics but I couldn't find the part listed either. It took removing a harness to find it on the CC ZTR that PTO was giving problems of just shutting down after I mowed with for 30 minutes. I would backup which disengaged the PTO but it would not re-engage going forward.
If you look at the image from my database you see several optional supplier PNs.
