Kawasaki FR730V engine will try to start and when you turn the key off it hums or whines like it is still trying to start
bcayce21
  • / Kawasaki FR730V engine will try to start and when you turn the key off it hums or whines like it is still trying to start
Should be able to get a new engine for around $2300.00 even for a FX series engine. What kind of starter did you put on it OEM of after market. If you would always post the Engine model and spec. no and model and serial no of the mower it would make thing a lot easier to access the information you need.
It was oem starter. Thanks for the information
hlw49
Really strange. What is the part no of the starter you put on it?
bcayce21
bcayce21
21163-0749​
hlw49
  • Item 21163-0749 is not available and will be replaced with the item below.
  • 211630804 Don't know if it matters or not.
bcayce21
