Couple of thoughts: Somewhere in Timken literature, the term used was "shield." This makes more sense than "seal" when grease/water/dirt can get around whatever is covering the bearing retainer.
I read Bert's post #7, just above, as the ZZ actually is a sealed bearing, as in nothing gets in or out ... ergo sealed.
However, we all just read Star Tech, post #6: "The bearings has to be change to ZZ bearings from the the 2RS bearings as the ZZ will allow grease to enter and exit the bearings while still retaining most of the grease." I read that as not "sealed."
123Bearing Co. calls the ZZs: "...  2 sheet metal deflectors, for dust-tightness. ..."
Are there no actually grease and water tight bearings available? ZZs cost more but is the difference meaningful?
RS is the designation for radial seal, which is a rubber seal and seals water/grease/dirt out (up to the point where pressure, vacuum, wear, or some other force causes the seal to fail). 2RS designates that there is one on both sides of the bearing. ZZ metal shields are not necessarily water/grease/fine dirt tight, but do keep the bigger stuff out.
I work in manufacturing, we also do some assembly. One of those assemblies calls for a 1RS bearing. The seal gets assembled on the environment (water/dirt) side, the 'no seal' side towards the grease fitting. The 1RS bearing is a special, the 2RS is readily available. We buy the 2RS bearing, pop 1 of the rubber seals out with a screwdriver or pick, and we're good to go. The 'no seal' side allows the grease to enter from the grease fitting, the seal keeps the environment stuff out and allows pressurized grease out.
I don't work in the mower world and am curious, do those of you who do work on them daily see more spindle bearing failures on the decks that have those garden hose ports built into them and used all the time?
