Kohler Courage 23 Valve adjustment. No lock nut? How do you adjust these?
OEFLep
So I have no need to adjust these until I started get the hard to crank issue. Knowing this is likely the valve adjustment, I got in there and there is no lock/jam nut. How do you adjust these and then not have it back itself off?
Thanks, Rivets and VegetiveSteam. There is only one elongated nut but I'll be checking both out.
Time to throw myself under the bus. There is indeed a torx set screw inside the long nut. I only looked at one end after I took the rocker assembly off. There is no sense in being stupid if I don't show it, how would anyone know? (Dad quote)
That’s how we learn. Something to remember on these. Often times if you try loosening the adjuster nut before loosening the set screw you’ll split the adjuster nut right in half. I don’t know how many of those nuts I had to replace on my training engines because guys liked to jump ahead as we were tearing those engines down and wouldn’t wait for instructions. Rarely would they tell me they broke one. They just left it for the next guy to find.
I appreciate the encouragement and I have to re-learn things sometime in my old age. Appreciate all the help too.
Just bought a TORO Z5030 with a 23 hp twin cyl. Kohler. Runs like a new one.
Ain't gonna touch it............yet.
"Adjusted" valves on a 23hp VTwin Briggs. Exhaust push,which is steel, came loose...."Shelled" the engine.
SRWA, please start a new thread. When you do so include all-engine numbers which will make it easier to help you.
