VegetiveSteam
- Jun 1, 2022
- Threads
- 0
- 400
I've added some info to my previous post if you want to look at it again.
I see what you added. That is terrific. There is no space limit on the air cleaner. I was prepared to make necessary modications to the wiring harness (figured at minimum that the newer engine uses different connectors than the old one), but maybe not (fingers crossed).I've added some info to my previous post if you want to look at it again.
Yeah, same wire harness part number so it should plug right in with no modifications. Exhaust will fit fine too.I see what you added. That is terrific. There is no space limit on the air cleaner. I was prepared to make necessary modications to the wiring harness (figured at minimum that the newer engine uses different connectors than the old one), but maybe not (fingers crossed).
It may take me a few weeks to get the swap completed, but I'll report back when I'm done.
Thanks again for the valuable input.
Is the damage on the bottom? closer to the exhaust valve? Crud packed on the outside from the area?
Same area on both sides?
Thanks to all the helpful input in this thread, I found a new Kohler model that replaced the engine in my 20 year old mower perfectly. Pic below. Machine runs great now.Yeah, same wire harness part number so it should plug right in with no modifications. Exhaust will fit fine too.
