- Feb 19, 2020
- Threads
- 120
- 12,865
Broke ACR on the camshaft was the most likely problem and that JD just didn't know their stuff. Like one here that told a customer his engine didn't have an oil pump when it had an oil filter. All they had to do was look-up the engine's IPL and they would had know it had one. All it was a loose wire one the oil pressure switch.Head gasket was never a problem with my machine. The oil level was checked every time and I NEVER saw oil leakage or low oil level.
To your point, my lack of small engine knowledge may have bit me in the *** this time. Turning the flywheel (?) at the end of the first year became very difficult. My assumption was, battery or perhaps starter (replaced both). Turns out, JD junk. And the dealership shrugged their shoulders. F em
My customer just quit letting the local dealer even touch his under warranty equipment.
