- Feb 19, 2020
- Threads
- 120
- 12,865
He will still have problems later as steel will rust. It is about all he can do to effect a repair though. Sometime it is necessary to do this. Stainless steel is about the only thing that not corrode in damp environments.
In this case it depends how meat is available as to which type of insert he can try. Heli coils takes up the least metal on resizing. Now of course there are other types thread repair inserts out there too. Hopeful he can stay centered up and square.
If has sheared off an extractor in the hole it will take a carbide drill bit the cut it out as they are that hard and he has to be careful as not to go too deep and penetrate the casing. This is when a drill bit depth stop (limiter) is useful. This has happen to me several times so learned to just drill out the screws with carbide bits as many are grade 8 and are heat harden further.
