Hammermechanicman
- Jan 10, 2020
- Threads
- 69
- 3,915
I have some of the plastic stops and have used the starter rope trick. I read on another forum that people have damaged the thin valves on the 4mix engines using the rope trick so I bought the piston stop.I don;t like using piston stops as to me they can put too much pressure on one small area. I keep a clean length of paracord to use as a piston stop.
MY PISTON STOP IS BETTER THAN YOUR PISTON STOP![]()
MY PISTON STOP IS BETTER THAN YOUR PISTON STOP.
