Stihl BR550. This a first
Nothing is 100% safe. As mechanic we all should know things can go awry at the least most opportune time.
I wonder how many people on here have used the rope method piston stop on a 4mix stihl backpack blower? You can't take the cam cover off so you either have to back the rockers way off or get just enough rope in the cylinder that when you crank about 75ft/lb on the fan nut that the valves aren't open.
Valves are never open at TDC of the compression stroke and the rope is fed in just before it gets there. Two strokes are so much easier.....
