PTmowerMech
- Apr 16, 2018
- Threads
- 440
- 3,393
From what I have gather from PT is the operator is just have a cutting problem with it cutting in a curve which is a sharpening problem normally but can be a bar issue too. His client may not even need a replacement BNC; although, depending the chain condition might need a new chain and rim provided the IPL is correct about it having a rim drive system.
The bar is worn out. The chain has way too much wiggle. It's stamped on the bar 050. And a quarter will slide into it a tiny bit. Plus there's a tiny notch on most of the chain tips (one side only).
