VegetiveSteam
- Jun 1, 2022
- Threads
- 0
- 448
The stator is putting out as it should and you've replace the regulator so you should be able to eliminate those two things as well as the flywheel magnets. Is the 6-7 vdc output voltage being checked with everything connected as it would normally be? If so, you should have at least battery voltage at the output side of the regulator. At that point your issue is somewhere between the voltage regulator and the battery. Wiring,key switch, connection, ect. If you're just checking the output side of the regulator without it being connected to the battery as mentioned, it will not function properly. The regulator has to be excited by battery voltage to work properly.I have a B&S Vanguard engine 356776-3046-G1. It is installed on an old Scag SWZ 52" walk behind, pull start. I am having problems with the PTO clutch engagement. The PTO would engage at first. But if it was hot and shut off, it wouldn't engage again. Then it stopped working all together. I checked the air gap of the PTO and the ohms reading is within limits. At full throttle, the voltage coming from the stator is 38V ac. The output voltage is only 6-7V dc. I replaced the regulator/rectifier with the same outcome, somewhere aroung 8V dc. Am I missing something? I have double checked the grounds, etc. Again, this is a non-battery system. So there isn't any back voltage requirements that I can find.
