I recently bought a old 112 with a Kohler engine.  after it runs for a short period of time it bogs down like it has a very heavy load on the engine.  Something internal is causing this load.  The governor opens the throttle wide open.  I have heard the stator may become overloaded.  I put a new regulator rectifier on it because it was not charging when I bought it.  But the new RR did not make any difference with the problem.  It does charge now at a rate of about 10 amps, maybe slightly less.  This tractor has an electric clutch. As soon as I idle the engine down it seems to be fine.  I would think if it were a mechanical problem such as a piston seizing it would stall at idle.  Any ideas?
Thanks
			Thanks
