LeakyBriggs
- Apr 26, 2023
- 29
Hello lawn and engine folks. I have a leak & question where I could use some Ideas or direction.
Have a Briggs & Stratton 22HP Intel V-Twin on a Simplicity mower.
Valve cover stamp:
Model 44K777
Type 0115 E1
Code 071015YG.
My issue is the O-Ring leaking at the oil pump cover.
Not leaking at the shaft seal, valve covers, or the large pan gasket.
I have clean, dried, and reinstalled with Permatex Red High Temp RTV. Still have the leak.
The O-Ring looks fine by visual inspection and is pliable without cracking or anything.
I can get a replacement and have no problem doing that but I'm suspicious of a loss of tolerance in some way for whatever reason.
So with that.... anyone know of a slightly thicker o-ring with the same internal diameter that would work and seal better?
Thanks for any replies.
Leaky.
Valve cover stamp:
Model 44K777
Type 0115 E1
Code 071015YG.
Leaky.
