Craftsman Garage
- May 2, 2021
- Threads
- 42
- 549
nothing better than the old stuff
This is where I'm at as well. Living in the suburbs, I don't want to deal with gas powered equipment although I do make an exception for my Stihl 194t chainsaw. I don't really need that much power for occasional limbing and would be totally fine with a Milwaukee fuel chainsaw 9/10 times but it's nice to have the power if I ever need it.At present, I think if most of your 'dollar-volume' is from commercial and large 'estate' machinery, I wouldn't worry too much.
As a homeowner with 9 years experience with batt-powered stuff, I can't see ever going back to gas. Doesn't mean I wouldn't switch back to ice in a heartbeat if I began having to maintain 'acreage' though.
Good point. I hadn't even thought of that, but you are 100% correct for crews in my area. I've not even a battery powered blower or trimmer. Imagine how many batteries a lawn service would have to own. LOL! They'd have to have a guy doing nothing but running batteries to the crews all day long. Also, imagine just how hard a lot of the guys on mowing crews would treat batteries. Those things would be bounced along like ping pong balls. Yep, excellent point, slomo.Haven't seen any pro yard crews running anything battery yet. That will tell you something. Those guys can tear up new anvils.
You brought up California. I know they banned gas powered OPE a couple of years back. Is that ban still in effect? If so, what the hell are they doing out there for mowing crews and lawn service? Are they actually using battery powered mowers for everything? How many batteries does a crew that mows large areas of grass use? There are countless places in California that have monstrous grassed areas around their huge office buildings and factories. Are they still only using battery powered mowers on those areas? If so, just how many batteries does it take?electric tools suck, i got an electric weewhacker. cooked in 10 minutes under some thin blackberries whereas my stihl weedwhacker cuts through em like butter. and who doesn't like the sound of the engines? yeah, your neighbors, but WHO ACTUALLY CARES? california politicians, that's who.
Bingo! These forced bans on gas powered equipment have at least two negative affects on the general public. Homeowners are forced to buy equipment with a very short life expectancy, at least when compared to gas OPE. On top of the short lifespan of the equipment, batteries have even shorter life expectancies. So, homeowners are bearing the burden of much higher costs to mow and trim their lawns. Then, it gets even worse for mowing services. Decent battery powered zero turns run AT LEAST $4,000 and most are more. Their batteries aren't lasting as long as they were advertised to last. Add in a little rough treatment by the guys employed by the mowing service and the things aren't lasting anywhere near their advertised life expectancies. That added cost HAS to be passed on to the property owner.That may be fine if you pay $99 like I did, but not if you are paying $4k for a battery ztr. That doesn't fly with me.
Yup it’s still in effect until republicans finally take control, then you can use your gas mowers again.You brought up California. I know they banned gas powered OPE a couple of years back. Is that ban still in effect? If so, what the hell are they doing out there for mowing crews and lawn service? Are they actually using battery powered mowers for everything? How many batteries does a crew that mows large areas of grass use? There are countless places in California that have monstrous grassed areas around their huge office buildings and factories. Are they still only using battery powered mowers on those areas? If so, just how many batteries does it take?
Just finished a 15 y/o cub cadet 1000 seriesBingo! These forced bans on gas powered equipment have at least two negative affects on the general public. Homeowners are forced to buy equipment with a very short life expectancy, at least when compared to gas OPE. On top of the short lifespan of the equipment, batteries have even shorter life expectancies. So, homeowners are bearing the burden of much higher costs to mow and trim their lawns. Then, it gets even worse for mowing services. Decent battery powered zero turns run AT LEAST $4,000 and most are more. Their batteries aren't lasting as long as they were advertised to last. Add in a little rough treatment by the guys employed by the mowing service and the things aren't lasting anywhere near their advertised life expectancies. That added cost HAS to be passed on to the property owner.
I have read articles and posts on other forums where guys are arguing until they're blue in the face that battery powered OPE is actually cheaper than ICE OPE because of the cost of gas and oil. They then compare the life expectancies of the two and that's when I get irritated. I have seen, time and again, statements that a gas powered lawn mower or zero turn only has a life expectancy of 7 years or, at most, 10 years. I suppose if you never did the first spec of maintenance on your mower it might not last over 7 years. I've got stuff sitting in storage, waiting on me to refurbish them, that are over 20 years old. Had these same pieces of equipment received just basic care they would still be running and serving their owner well. I did a refurb on one mower recently that was given to me at no cost because the owner said it was junk and wouldn't run. I dumped the old gas, pulled the carb, stuck it in some paint thinner, blew it out, put it back together, then finished the servicing, and it fired and purred like a kitten. The other thing I found was that the blade on the thing hadn't been removed and sharpened for a LOT of years, if ever. All that was left was a slab of metal, half the width as when it was new, with the front edge rolled and blunt. THESE are what those articles are using as evidence that ICE OPE won't last over 7 years. Irritates the crap out of me.
No, I don't think we are at the point where battery powered ANYTHING is better than the old ICE stuff, and that includes cars and trucks. Whether we like it or not, it seems U.S. government agencies are dead set on outlawing anything powered by gas, diesel, kerosene, LP, or natural gas, including cook stoves. I still can't believe they are attempting to outlaw a danged gas cook stove. WOW!
