When the Chinese companies started selling and not supporting crappy parts. Both eBay and Amazon have a lot of bad actors making it nearly impossible to trust any after market company.Since when did the word AFTERMARKET become a bad word. I sold Aftermarket Automobile parts for over 50 years. There are good Aftermarket Parts and there are bad Aftermarket Parts! Some Aftermarket Parts are manufactured by the same people that got the low bid for the OE. Why in my first 30 years when I told people that I was a rep in the Automotive Aftermarket, they didn't know what Aftermarket meant. Now it means bad? Cheapest is not always best, and neither is OE. Look for parts manufactured by a reputable manufacturer and remember you usually get what you pay for!
Even the JD A&I division has gotten burned by having bad products. I know as I was a dealer for them and the aftermarket parts got so bad that I had quit buying them from them. Belts were constantly arriving 1 to 2 inches short. Spindles assembled wrong. They even tried conning me on the OEM Zama carburetors by sending me aftermarket ones that didn't work.
I am currently a dealer for both Rotary and Stens. Recently I had ordered 5 JD spindles from Stens. So far two were already returned due to failure due to assembly errors. First one had an incorrect spacer and the second one had the wrong pulley adapter nut. Customer is the same one and is on his third one now. Two of the Five spindle is still on the shelf but I probably will have problems with them too. So Stens has honor their warranties and I haven't been with Rotary long enough to run into problems though I have used their products for years without problems.
