Only one problem with those inline spark testers. They indicate spark even when the plugs are shorting to ground. And plugs with cracked insulators can short when hot. Plus testing plugs out of the engine's compression zone only confirm they fire outside the compression zone. They still can misfire under compression.
I even had one plug a few years ago to cause dieseling under compression load at full throttle only which push beyond the coil's rpm limiter.
It takes experience to diagnose some problems. Yes basic problems are easy but there are unique problems sometimes.
On top of that just because a plug is new doesn't mean it is good. That is why you must a known good plug for testing.
