I have a 2007 John Deer tractor with a briggs and stratton engine with 508 hours, the oil has been changed every 25 hrs and the oil filter changed
every 50 hrs, the engine runs great for about 1 hour, while the engine is under a load, blades turning, the engine will stall until the blades are disengaged
then runs good again just moving forward, the only smoke i see is coming from the fly wheel when I stop the engine, does not burn oil, any comments would be
greatly appreciated
greatly appreciated
