PTmowerMech
JD D160
Briggs 44S977-0026G1
Customer complains that she's having to go over most of her yard twice. I got it here to the shop and started mowing and she's right. After mowing a few stretches, and it looks almost like when you mow in reverse.
So I sharpened the blades, leveled the deck, and it's better, but still not cutting like it's got freshly sharp blades on it.
Belt is good. Pulley's are good. PTO seems to be engaging fine. Fast idle of the engine (briggs twin) is 3130 rpms on both sides. Engine sounds and runs fine. I didn't have any tall grass to see if it would bog down too easily, but what I cut was a couple of inches taller than the deck level. There was on place where a mower had been sitting for a few weeks that was pretty tall. Not real thick grass, and about 10" to 12" tall, I had to go over it twice too.
