Clunk sound when trying to start
hotheaded22
With original solenoid it makes a loud clunk sound from under the seat, i put a universal solenoid on and it makes a high pitched whining sound as long as the key is turned. Good battery and cables, I checked with a multi meter. Only getting about 5v at the starter with original solenoid, 12-ish volts everywhere else. Any ideas would be greatly appreciated.
I would start by putting hands on the flywheel and make sure it will turn a complete revolution. That description hints of a seized or hydrolocked engine.
hotheaded22
Ok, tried that and it doesn't budge. So. I'm guessing have to rebuild or replace engine.
reetkid22
no pull out the spark plug or plugs, and try to turn it over. look for fluid coming out of the spark plug holes as you turn it over. if there is fluid and it turns over then its hydrolocked. if there is no fluid than its another issue.
A loose or broken magnet under the flywheel can lock an engine solid as can a surpprisingly small piece of gravel .
