- Nov 29, 2014
- Threads
- 65
- 24,995
Usual cause is overheating
The valve guide shifts so the valve spring becomes coil bound before the pushrod has finished pushing
Other cause is the valve hitting the piston
Inlet & exhaust cam , pushrod & valves are the same lengths so should sit exactly in the same position when unloaded
