FarmerCharlie
- Mar 22, 2011
- Threads
- 13
- 46
When I got the mower back from the shop after the spindle replacement, I mowed a couple of acres when all of a sudden the blades stopped turning. The deck belt was fine. When I tried pulling the PTO switch, nothing happened--not even a click. When I got it to the garage, I noticed that the connector to the clutch seemed a little loose.
When I wiggled it, it came loose totally.
I pushed it back on, and it was working again, but then came loose again a few minutes later. I noticed that the connector did not click when I pushed it on, and I don't see any sort of locking mechanism on the clutch to match the tab on the connector.
The repair shop did say that they had to remove one of the pulleys to replace the coils. Maybe something broke off the connector.
Anyway, can someone explain whether the connector should click and lock when I connect it? My connector
looks exactly like this one on Amazon. https://www.amazon.com/Rotary-Harness-Electric-PTO-Clutch/dp/B005ERKNP6
Although my little 42" EGO ZTR works surprisingly well, it's not all that great for mowing 7 acres or trails through the pasture.
Thanks,
Charlie.
![20220720_131839_1000T.jpg 20220720_131839_1000T.jpg](https://www.lawnmowerforum.com/data/attachments/50/50506-9e727d46397bb3912dc678c5fb44e646.jpg)
![P1060078_1000T.jpg P1060078_1000T.jpg](https://www.lawnmowerforum.com/data/attachments/50/50507-618b60f601580ea70d5e4060b48908c7.jpg)
![P1060084_crop.jpg P1060084_crop.jpg](https://www.lawnmowerforum.com/data/attachments/50/50508-656a02d6067d283ee342743115ebc02d.jpg)
Thanks,
Charlie.
