Snapper Pro S150XT not cranking - Fuel problem...
blakeaf96
Snapper Pro S150XT
Dirty gas was ran in both tanks and it bogged down when cutting and won't crank.
- Turns over just fine but does not crank
- Fuel lines are free of debris
- Both lines on both tanks that feed into the fuel tank are free of debris
- Installed new fuel filter
- Fuel pump has been tested and spits gas out when I disconnect line feeding to carbeurator
What could be the issue? I haven't done anything with the carb yet - Starting to wonder if that's what the problem is. Any ideas?
Thanks everyone!
I've noticed there is barely any fuel in the fuel filter after I replaced it with a new one. Tiny tiny bit of fuel is all.. What would cause it not to fill up? Fuel pump not working correctly maybe?
I like the gas and mud solution myself. That said, my bones are feeling another spammer attack coming on. How do I get rid of that?
