Snapper Pro S150XT
Dirty gas was ran in both tanks and it bogged down when cutting and won't crank.
- Turns over just fine but does not crank
- Fuel lines are free of debris
- Both lines on both tanks that feed into the fuel tank are free of debris
- Installed new fuel filter
- Fuel pump has been tested and spits gas out when I disconnect line feeding to carbeurator
What could be the issue? I haven't done anything with the carb yet - Starting to wonder if that's what the problem is. Any ideas?
Thanks everyone!
Thanks everyone!
