Stryped
I am rebuilding a Briggs v twin 27 hp 49 series after the rod broke.
Buying a gasket kit on Amazon. The kit comes with new valve seals but should I use them? The engine did not smoke when it broke the rod. I am a little afraid of replacing my valve seal with a made in china seal if that makes sense. I tried replacing the pto seal once with a cheap seal and it kept falling apart during installation. New Briggs made seals are as much or more that this gasket kit.
Thanks!
Thanks!
