Alex Ethridge
- May 25, 2019
- 97
It was running fine, then ignition seemed to miss a time or two over about 15 seconds then went dead. I do have spark, tried starting fluid but then removed the air cleaner. Long story short, when engine turns over, it belches gasoline out the intake, lots of it. Probably less than 20 hours use on the mower (residential & relatively small yard).
I cut the fuel supply and turned it over a while and I guess it cleared the flood as it started and ran a minute or so, I guess until it burned the fuel in the line.
There are some wires connected to the bottom of the fuel bowl. What is their purpose?
Suggestions?
Suggestions?
