- Feb 19, 2020
- Threads
- 110
- 12,249
Just note for some folks it does take a while to get back to a project. All kinds of delays can happen and of course when they get it fix they don't let us know either a lot of the time.
Personally it has been a rough start this year for my business. Delays in parts delivery, customers not mentioning problems, and of course weather delays.
It like the JD Z925A. Came in with a known bad spindle, one ignition coil failing, and parking brake safety problem. Took the mower out for after repairs. First thing right front wobbling all over the place. The bolts holding it arm on was way loose. And while mowing heard a bearing in an idler pulley bearing going bad. Well it back down under I get the 6006-RK bearing in. Meanwhile there is a few other parts that got to be ordered too as the brake linkage is rusted solid and a missing J bolt, nut, and sleeve for center anti scalp rollers. Then there the Scag that came in for maintenance with a hydro oil leak. Resealed unit and service the engine. LF tire was flat so went to repair that. Just leaking around the bead. But I was put on a hold due a seal missing. I still trying to figure how there is no sign of the seal. Should have been a least a metal ring left. Tapered bearing completely impacted with dirt. Seals arrive at closing Saturday. Maybe I can get it out Monday before the rain arrives yet again for another 4 days. Rats...
Then of course was the Yamaha 660 where it need a fuel valve and had a loose battery cable. Repaired those to only find out the supposedly just repaired carburetor wasn't repaired. I had order a kit for it. Then as I was getting all that together that customer mentions the throttle cable sticking. At least I went ahead and got a new fuel level sender. Well I finally got it out but I would not go above 40 mph as I was uncomfortable going any faster.
He was already soaked for a half A job by another shop. He claim they supposedly soak the carb in lemon juice. Well no signs of any cleaning. The secondary fuel filter screen was completely clogged with rust where they only remove the filters in the tank. Even the jets were loose and one had completely fell out. If they rebuilt the carb there should have at least been new o-rings but none were found.
Then there is the darn Polaris 90 that is back again after the customer put in some old 2 cycle oil and it start missing and wont idle. Just had rebuilt the rear end.
Why can't the customer just let know us of all the known problems ahead of time so all the parts can be ordered at the same time. Things like above just throw a wrench into things causing a lot of delays. Plus it adds to cost of repairs as in the Yamaha where I had to charge double for the labor because I had disassemble and reassemble twice the tank area.
Ranting over. I still got a couple hairs left...
As for the problem the OP mentions I have seen it once on an opposed engine where the ignition coil would heat soak while sitting and the electronic fails until it cools back down. In my case it was a borderline good Magnetron coil.
And yes we need the equipment info as it does help to troubleshoot remotely as well as to suggest the correct replacement parts.
Meanwhile I killed one my kids yesterday and going to BBQ her today then pass out the BBQ to my neighbors. So they all will be guilty of eating my kid.
