fullboogie
My mower is an HRR216VKA that was purchased about 4 years ago. I've used the guides on this forum to "fix" the locking up rear wheel problem many times and I'm just tired of it. Each season I pull everything down, clean/polish/grease, and put it back together. I even have the "recall" rear adjuster/bushings on there. And still, I make it a few months at most and the problem returns.
If Honda has moved on to another design that fixes this problem, which model(s) should I be looking at? Cost is not an issue. I've Googled and searched this forum, but I've only found the older threads that address the original problem. Unfortunately I've seen one or two HD reviews for the $700+ HRX models that mention the same problem as recently as 2021. I've not seen anything about a redesign from Honda that fixes it. Thanks guys.
