skipper124
- Nov 7, 2019
- Threads
- 11
- 40
After about every mowing I scrape and brush off the clumped on grass and paint brush some used motor oil on and have not rusted out a deck yet and it's cheap!
I
You are trying to prevent rust from the underside which is not usually a problemThanks for the suggestion but when I looked for the POR 15 Chassie coat, I don't see which one you have suggested. Is it the Bed liner & undercoating or topcoat or the 3-step rust preventive system?
Thanks, Mike
Problem is decks are getting thinner and lower grades of steel are being usedWhat are you trying to achieve? Longer lasting deck or easier to clean?
I just stopped using a 1996 Cub Cadet 2165 for mowing that I mowed 2+ acres with for 24 years. It has an 11 gauge deck and after most mowings, I cleaned it out by hand to get the big clumps out so as to keep air flow okay. I never made it a priority and there was usually a lot of wet grass stuck to the sides after I was finished. Something that I ran over finally punched a small hole in it and I knew it was getting thinner from rust so I bought an Exmark. But, it still lasted me a QUARTER century!
I wouldn't over-think it.
NO
Teflon paint is designed to prevent oily things from sticking like crayons cooked food etc
It will probably go some way to stop build up under the deck for a couple of months till it s abraided away
As Star has already said, the underside of a deck is the equivalent to a sand blasting cabinet
If the grass & grit can wear through 1/4" of steel hardened to 65 to 80 Rockwell on your blades what chance does a paint have
Just have a think about it
If it is hard enough to resist the abraison then it will not be flexiable enough to resist the abraison.
Add to that cut grass is very acidic so there is a chemical attack as well
I have used undercoating, car. Spray it on after your. cleaning process . Put on one coat on and let it dry before dry before you spray on the next coat. I have sprayed up to 5 coats using the undercoating and it did the job. It looks just like it did after 2 years of use. Hope this helps you and you get the problem solved
Thanks, Mike
