NO
Teflon paint is designed to prevent oily things from sticking like crayons cooked food etc
It will probably go some way to stop build up under the deck for a couple of months till it s abraided away
As Star has already said, the underside of a deck is the equivalent to a sand blasting cabinet
If the grass & grit can wear through 1/4" of steel hardened to 65 to 80 Rockwell on your blades what chance does a paint have
Just have a think about it
If it is hard enough to resist the abraison then it will not be flexiable enough to resist the abraison.
Add to that cut grass is very acidic so there is a chemical attack as well
