- Feb 19, 2020
- Threads
- 116
- 12,598
Hammer Gee Whiz I was talking the younger generation [under 25] coming online. I recently had to try to get the JD Stihl tech to repair a hedger. He couldn't do a pressure/ vac test on it. Nor could find a bad spark plug that had it dieseling. I end having to fix it for my customer out my pocket to cover the warranty. So embarrassed that was the best they had for a tech.
I have did several Stihl chainsaws in the last few years and didn't really need the tool. For the brake spring may have used one my spring hooks here. I usually make my own so they are custom made for certain work. It sorta like the custom installation wrench I made to tighten up the oil drain on the Kawasaki engines. A regular crow foot will not work.
I still working on (in my head) on a spring hook tool for a Cub Cadet ZTR drive spring that is a royal pain to get on the hook tab. Luckily I only see these once every couple years so it is not a priority here.
Since my machinist retired I got to get my own lathe now so I can continue to design and make custom tools for my job requirements. It like the PTO clutch tool I use for torquing the mounting bolt when the Double D are involved. I now need a 46mm version.
