Hammermechanicman
- Jan 10, 2020
- Threads
- 69
- 3,939
When something with a battery comes in the shop i use an internal resistance type tester to find the health of the battery. Then i clean battery connections and start the equipment and run it up to about 3000 rpm and check voltage at battery to see if it is charging and then turn on any accessories like cluth and lights and measure voltage at batter for charging voltage. If it has about 13.5v or better i call it good and move on to other maintenance. I am sure the internet will tell me i am wrong but i try to not over think a lawn mower charging system. Don't really care if it is peak to peak, RMS or average volts. My meter is a true RMS meter but doesn't matter all that much.
