Craftsman T310 Brake Pedal Lock
tscovill
In order to lock the brake pedal it must be pushed so far down. Too far. Is there an adjustment that will allow the lock mechanism 6o kick in earlier?
No
The latching mechanism on most mowers is fixed but occasionally some come loose
Get a strong torch out and have a good look at the latching mechanism
It is usually under the floor but on a few mowers it is behind the dash.
On some occasions I have needed to resort to a file because stuff does not quite line up
And yes this is general
If you want better we need the entire model & serial from the ID tag under the seat so we can check the IPL
No
On some occasions I have needed to resort to a file because stuff does not quite line upIt is usually under the floor but on a few mowers it is behind the dash.
Thanks, I believe this is the mower information from behind the seat
Craftsman Mod #13AQA2ZW093
SER.TD14MH20083
