No
The latching mechanism on most mowers is fixed but occasionally some come loose
Get a strong torch out and have a good look at the latching mechanism
On some occasions I have needed to resort to a file because stuff does not quite line upIt is usually under the floor but on a few mowers it is behind the dash.
And yes this is general
If you want better we need the entire model & serial from the ID tag under the seat so we can check the IPL
Thanks, I believe this is the mower information from behind the seat
Craftsman Mod #13AQA2ZW093
SER.TD14MH20083
