Hammermechanicman
 - Jan 10, 2020
- Threads
 - 69
 - 3,915
"It's a lawn mower, not the space shuttle" to quote a utuber. And i agree.
			This will change the timing of the spark or top be more precise allow the spark to jump at a lower voltage .Standard copper plugs with no resistor if you can snag them. No need to reinvent the wheel.
And many a tug to fire off the ol' girl.Back in the 90s the 5hp briggs go cart racers had the resistor vs nonresistor debate. The most difference i ever saw was about 1 degree of difference which is insignificant in any stock enhine. On some small 2 strokes with low energy magnetos using a resistor plug OR too wide of a gap can cause poor running due to misfires.
Why dual spark plugs? Is it for redundancy sake or a more thorough burn?I'd say iridium are for sure "better" technically and they will last longer assuming you have no negative factors affecting the plugs like overheating or fouling. With that said - will you EVER realize any real benefits to justify the costs? Probably not.
Our airplane has a 5.9 liter 6 cylinder air cooled engine making 200hp turning 2700 rpm with dual spark plugs and dual independent magneto fixed timing ignition. Fairly similar to a mower engine in hp per liter and RPM. We run iridium plugs in it because of significantly longer plug life, slightly better low idle smoothness (maybe), easier starting (maybe), and reduced maintenance because the electrodes for them are smaller and re-gapping isn't required. Regular copper plugs last ~400 hours in an aircraft engine, and iridium plugs (also known as "fine wires") can last up to 2000 hours. It's worth it on the aircraft despite some absolutely eye watering prices.
I wouldn't bother on a lawn mower engine though despite the technology being superior. It just doesn't practically make a big enough difference and swapping a plug on a mower every 250 - 500 hours and takes all of 2 minutes and will probably never save you money or hassle.
Yes it's better, no you probably don't need or want it.
