 - Feb 19, 2020
- Threads
 - 118
 - 12,658
Once aluminum to steel transfer begins, just unjamming it will not fix the problem. All it going to do is to throw a rod threw side of the crankcase. The transfer must be removed and new parts installed. Plus you most likely find that the head gasket is blown which caused the loss of oil in the first place.
