Can you name this part?
Gardenwalla
My Cub Cadet xt1 is missing the part which attaches front of the mower deck to the mower itself. It is a rod with a cotter pin at each end. The rod itself is seen in a Youtube video I did a screenshot of. I circled it in blue.
Can someone name this for me so that I may order a replacement?
Scrubcadet10
Moderator
Staff member
give us the model number from under the seat, should start with 13_________ and we can give you the correct part and part number.
DECK FRONT LIFT ROD
You adjust it to adjust the deck level front to back.
And cub have all their parts books & manual on line so get a copy & keep it on your computer or print it out
Ronni
On my LT1045 mower, it is called a deck rod that supports the height of the front of the mower deck.
Gardenwalla
Thank you so much! The number is 13A9A1CS056.
You have helped this old lady to save some money!
