- Feb 19, 2020
- Threads
- 118
- 12,664
NO they do not contain every wearable part just the common ones.
Well there are GND and Carb repair kits but if the primer base check valves are bad neither will repair that. Nor do they repair a bad main nozzle and damage check valve in the carburetor body. For the DIYer that has no idea of how these carbs work or how to check them then it best just to replace the carburetor.
I clean and repair a lot of these carburetors but even there are times they simply can't be repair due lack of parts ot the parts are too costly.
