Stihl FS38 trimmer primer bulb sucking air in and runs badly
XGamer223
  • / Stihl FS38 trimmer primer bulb sucking air in and runs badly
There is a limiter to prevent richening up the screws very much, so pulling them is what is next to be able to richen them further.View attachment 57455View attachment 57456
Hi and thanks for your answer.
But this isn't it, sadly.
I placed a 100% working carb from a different Stihl, and the trimmer works just fine, so that concludes that's a faulty carb, not the fuel lines, filters, and what not. Also note: the carb I placed it on still has the limiter caps on it.
Thanks anyways, and sorry for my late answer!
C1Q-S97
Fish
Was the throttle cable ends different?
The FS 38, 45. and 46 use the same parts most times but are some differences noted in the IPL for the three.
Fish
Yes, the units have had some minor changes, the throttle cable ends, and slight changes in the air filter assembly, handle, etc.., but the 4140 powerhead has been pretty consistant. The throttle cable end change has forced me to include the throttle cable with the carb on my listings.
Also it is the same powerhead as the fs55. I popped one on a fs55 rig and it is great.
Fish
Here is the one I sell, the cable has the z-bend end.
XGamer223
Bump.
Anyone got any insights?
You have already got it down to the carburetor as being the problem. Sometimes these carburetors are just beyond repair and has to be replaced. I had primer base to go bad and they cost a much as a complete carburetor.
XGamer223
So, no repair kit they sell online wouldn't help? Seems to me that it contains all the wearable parts.
But anyways, there's an obvious issue with the carb. Even though, at some trimmers I've seen online, the bulb acts the same as mine. Maybe the problem lies somewhere else, since it doesn't run good. I might give it a good clean again.
