- Sep 24, 2017
- Threads
- 283
- 6,839
Because guessing won't cut it.
Which engine and what type of starter ?The guy has a badboy magnum, he washed with a garden hose it is quite obvious the problem. Why would you need numbers. Lol
I could ramble on about water causing a bad body ground on a 3 post solenoid which would be just confusing if he has a Kohler or Kawakasi fitted with a shift starter .
This is even more important with people who are unfamiliar with mower repairs because they get confused looking for parts that they were told cause problems which are not fitted.
Was this in your mower or engine manuals? Just asking as water tends to rust everything and corrodes electrical items.I washed my bad boy magnum lawnmower with the hose after mowing
Should have a clean your cooling fins super stick em' too.Another missing Stickie... instructing first time posters to be sure and log the brand, model, model number and some photos.
