Snakebstr43
- Jul 13, 2021
- 6
The first problem I had with it was it was alittle hard to start ever since I replaced the choke cable. Then it would start after a few minutes of figuring out where to set the choke. It ran for a while like that then about a week ago I noticed when I was mowing it would shut off after about 20 or 30 minutes of mowing, but I could start it right back up, mow a row or two and stop again. I did research and came to the conclusion the fuel solenoid was bad, but I replaced fuel pump, fuel filter. Before I could get a solenoid installed I cut one last yard and it ended up being a total pain, litterally shut off every row until finally it just wouldn't start.... so I pushed it up on the trailer and that's pretty much where I'm at now..... I finally got a new solenoid installed and it still won't start..... turns over but just won't start. Any ideas? Thanks
