CharlesHowse
- Jun 26, 2021
- 5
Hi, Charles from TN here.
My Ariens A21AH2 is giving me a big headache. Several years ago I disabled the seat safety switch and it ran perfectly for a long time.
A week or so ago I replaced the drive belt. No problems with the routing, just took a little while.
My grandson was mowing 2 days ago and suddenly the blades quit spinning, and the motor started backfiring and missing, and finally quit.
Apparently, in the time between disabling the seat switch and 2 days ago, the cable from the seat switch (which I had tucked into the battery compartment) had slipped out of there and down into the belt and gears just below, and was cut and mangled, connector and wires both gone.
There's nothing wrong with the belt or deck, I disconnected the belt to double-check., but the engaging the blades kills the engine.
Got's to be related to a safety switch, I'd say.
I assume that's the issue with the blades not starting, what's left of the seat switch is sending a ground to the magneto as a safety measure.
I've been on YouTube all day yesterday and today, and haven't found a fix.
How can I verify and repair/disable this issue?
Thanks,
Charles
Thanks,
Charles
