Hi, I am looking to buy my first ZTR. Should I go for a mower with EFI? Is it dependable? Are there problems with fuel pumps, sensors, filters etc... any more than with a carb? Which way should I go?
EFI is really only economically viable for commercial mowing.
Not too far down the track all petrol mowers will be EFI as emission standards get tighter than a carburettor can attain.
Untill then stick with carbs which are owner servicable
I agree with the above posters. As a commercial mower I will add this for your consideration.
The EFI burns a lot less fuel
Starting is much simpler all year long
With proper maintenance both will go a long time. Two of my mowers hours
Vanguard 35 hp carb 2000 hrs
Vanguard 37 hp efi 1400 hrs
Doubt that there is much of a fuel drinkage difference. Probably low enough to not even worry about it. All these especially over 14hp motors like the fuel.
We have EFI on our JD tractor. It's the most reliable piece of equipment ever owned and NEVER a fuel related issues in over 24 years. I wish our motorbikes had it because it's nerve racking every Spring not knowing if the carbs are going to be unhappy or not.
I think the electronics in our refrigerator are more problematic if things go wrong.
