Gord Baker
NEVER jump a lawnmower from a Car. You could destroy the Charging system. Check Lawnmower Negative ground connection to frame. It should be shiny and tight. Attach + battery side to Starter electrical lug with one cable. No open fuel around.Obviously some thing is not good so please do the following and report back
Grab the jumpers from your car boot and jump from the battery negative to a good ground on the engine ( drain bolt is usually a good place ) .
Cranks fine = bad ground strap
No difference the hook the other jumper from the + on the starter motor then to the + on the battery
Engine cranks = faulty wiring
Engine does not crank = bad battery or bad starter
Repeat all of the above with a know good battery like from your car
BEcause the JD technical manuals are so well written & so comprehensive , particularly in the way they describe how to test the electrical system & where to test the system I always recommend owners buying them.
COnsidering the price is only a couple of hours of the technicians billing rate they are dirt cheap .
