hotroddr32
- May 16, 2021
- 7
I have a 21hp Briggs Intec on my Husqvarna riding mower that got a lot of water in the tank, I've gotten all the water out of the system and took the nikki carb down and cleaned it out. Now it fired up but was backfiring really bad and wouldnt run much. I found bent pushrods on one cylinder due to backed out valve guides. My question is what is the chances of something like a cam or tappet is damaged too or should I just figure its all right there at the head? I understand the pushrod is basically the sacrificial lamb so that other vital components does not get damaged, but I just wanted some assurance. Also is it a waste to even try to fix the old head or just buy a new one. Looks like the other cylinder is ok. Thanks!
