- Feb 19, 2020
- Threads
- 118
- 12,662
As a self trained mechanic I have learned to pa attention on how things comes apart in order to re-assemble. When I use was a kid my self father would create all kinds of puzzles for me to work out. He even had rebuilding an Oldsmobile V8 head when I was only in the second grade. After which he checked my work and then installed the head. I do have the ability to disassemble, move things around, and assemble things in my head. Not all of us has this ability so taking pictures as you take things apart helps on reassembly.With regard to "where can I get the cheapest 'xyz'?" I try to buy the brand that made the machine. It usually turns out better.
In this case the service doesn't give step by step instructions for this removal.
Anyway take your time for at the first time around doing this job; meanwhile, I going out to tear down a 2014 Honda TRX500FE atv this morning. I havent done this model before so it probably take all day.to get the CV axles out for rebooting but first I got the replace a head on Sentar Kawasaki v twin engine.
