Yard Troll
Fourth time using the 2021 model and the drive belt was severed. Replaced the belt but now the deck belt vibrates against hydro gear housing. Tension springs were put back on the way they came off. Does the tension need to be adjusted on the deck spring even though nothing was replaced on the deck?
