The Brain
- Jun 26, 2019
- Threads
- 8
- 77
09 snapper RER engine swap intex 12.5hp
The orginal engine’s valves are worn beyond adjusting, starter was almost dune.
Now I believe a broken compression lobe of cam.
sure I'd love a honda however I'm swapping the exact same intex.
Seller says next engine runs good it’s a ebay deal.
I think this could be a easy swap I hope.I think the diistance between static drive & bottom of case is the hard part.
Howes a easy way to gain slack in the drive belt so I can slide the static drive disc. Over the belt.
I'm thinking the pulley w/ the L brakect can be removed to get the slack seat belt around engines pulley then tighten belt at the same pulley w/ L brakect. sure hope this goe's smooth I'm allready 2 weeks behind in the back front is still good.
new used engines crank snout/shaft has surface rust maybe a steel wool smoothing?
thanks for advice.
thanks for advice.
